gadgevxr Posted June 24, 2007 Author Posted June 24, 2007 thats the dvr setup out the window then. Will have to be IP then wont it? seen this, any good?
alterEGO Posted June 24, 2007 Posted June 24, 2007 thats the dvr setup out the window then. Will have to be IP then wont it? i can't really go any further in advising you as i don't recommend or use single IP camera setups. good luck
gadgevxr Posted June 24, 2007 Author Posted June 24, 2007 i can't really go any further in advising you as i don't recommend or use single IP camera setups.good luck np, thanks for your help anyway
Guest anguscanplay Posted June 24, 2007 Posted June 24, 2007 thats the dvr setup out the window then. Will have to be IP then wont it?seen this, any good? nope fixed lens , woeful resolution and generic mass produced
gadgevxr Posted June 24, 2007 Author Posted June 24, 2007 i've seen this but i would need a dvd recorder wouldnt i? also seen this
Guest anguscanplay Posted June 24, 2007 Posted June 24, 2007 i've seen this but i would need a dvd recorder wouldnt i?also seen this go with the tesco ones i showed you lol spend as little as possible because at this level
alterEGO Posted June 24, 2007 Posted June 24, 2007 go with the tesco ones i showed you lol spend as little as possible because at this level
gadgevxr Posted June 24, 2007 Author Posted June 24, 2007 I'll fit it myself, i dont mind and enjoy fitting new toys, after all im a proper spark (not a house basher) does black and white make a difference in cctv world compared to colour?
alterEGO Posted June 24, 2007 Posted June 24, 2007 I'll fit it myself, i dont mind and enjoy fitting new toys, after all im a proper spark (not a house basher) in that case why are you looking in argos? i would have thought your wholesalers would have a cctv section? most have a small selection. and whos the house basher? most of us on here undertake all aspects and have a wide range of knowledge and skill hence you asking i suppose. the bottom line is you don't have a big enough buget to get a decent set up and that being the case they are all as bad as each other so it dosn't make a great deal of difference which you choose. as i said if you increase your budget we could spec a system for you and offer fitting but i'm sure you are more than capable of putting the cables in, just nothing to put on the end
gadgevxr Posted June 24, 2007 Author Posted June 24, 2007 im not self employed. hence argos. house basher is term for a house spark or cowboys as they/we frequently get called on here! Im just after basic cctv setup to watch over car should anything happen, thats all. At first i was just going to get a 40 quid wireless job off ebay but i think its a case of what you get is what you pay for. all help is appreciated tho!
