gadgevxr Posted June 24, 2007 Posted June 24, 2007 From what i've learned, an ip cam is independant and doesnt really need a pc to be connected unless you want to record? Now if i was to have a dedicated pc for one outdoor cam, can i use any camera then?
luggsey Posted June 24, 2007 Posted June 24, 2007 hi theremy advice to you would be not to use a pc as a recording device as it is prone too much to crashing and viruses wether its a dedicated pc or not. my professional advice is use a standalone dvr maybe from screwfix or HERE and connect a coaxial camera with a bnc type plug and psu as in my opinion the images and quality of the camera both day/night, coloour and mono cameras far outways the ip based systems. if you still wanted to use a pc then you would need a dvr card which plugs into the pci slot in the back of the machine. hope this helps. colin I use a PC DVR card in a XP machine running 24/7 with no problems whatsoever, standalone DVR's are really cheap now though...... ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
gadgevxr Posted June 24, 2007 Author Posted June 24, 2007 seen sd dvrs for 60 quid, then i can pay 40 quid and add a camera. just seen that the dvr records at 8 fps. rubbish really
Guest anguscanplay Posted June 24, 2007 Posted June 24, 2007 try this dvr i have used it, and it wasnt too bad. might be ok for what you need?dvr sweet ##### why am i spending over a grand a time when i could use that ? 3 days of realtime recording , well 4cams into 25 fps you got any footage to post bellman?
barooga Posted June 25, 2007 Posted June 25, 2007 From what i've learned, an ip cam is independant and doesnt really need a pc to be connected unless you want to record?Now if i was to have a dedicated pc for one outdoor cam, can i use any camera then? Similar rules apply here has they do to your question regarding cameras. If you don't wat to pay sensible prices, don't expect sensibly performance. Growing old is mandatory, growing up is optional
Nickolas Posted September 19, 2007 Posted September 19, 2007 Dear gadgev, you do not need any special device to view ip camera through network. Camera and PC need to have network connection. You need to know camera's ip address and type it in InternetExplorer. You should get view. Good and reliable software for 4 cameras which can record and transmit through network and UMTS/GPRS/GSM with watermark and many professional functions are available for over 100 euro. I have written article about it in Security Park: www.securitypark.co.uk/security_article259880.html
