lgal2004 Posted June 24, 2007 Posted June 24, 2007 Hello, Help! I have a problem with a Securitech 700L. The tamper led on the remote keypad will not go out. I have shorted out the tamper circuit in the panel and the tamper led is still on??? I have also tried shorting out the tamper circuit in the remote keypad and the tamper led is still on. I dont have a user manual. Is there a reset on the Keypad? eg code + what? Or does it mean the remote keypad is simply goosed?
kka Posted June 25, 2007 Posted June 25, 2007 there may be two other tamper circuits , the keypad tamper, and bell box tamper. Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
FASTCAR Posted June 25, 2007 Posted June 25, 2007 Hi , Code + # is RESET. But it sounds like you have more than one tamper circuit open...or your panel has frozen , (do the keys still beep when pressed?). Regards.
Guest anguscanplay Posted June 25, 2007 Posted June 25, 2007 there may be two other tamper circuits , the keypad tamper, and bell box tamper. de dede de deda and also the battery lol angus
lgal2004 Posted June 25, 2007 Author Posted June 25, 2007 Hi , Code + # is RESET. But it sounds like you have more than one tamper circuit open...or your panel has frozen , (do the keys still beep when pressed?). Regards.
lgal2004 Posted June 25, 2007 Author Posted June 25, 2007 Hi , Code + # is RESET. But it sounds like you have more than one tamper circuit open...or your panel has frozen , (do the keys still beep when pressed?). Regards. Yes the keys beep and it also beeps on the exit but does not set.
FASTCAR Posted June 25, 2007 Posted June 25, 2007 There is also a tamper circuit for the bell , and a tamper switch for the cover of the main box, go back to the begining , check all tampers and reset the system.
