Guest tony5436work Posted April 16, 2004 Posted April 16, 2004 Evening all, Just wondering if anyone has much working with the abacus 15p model? I have the normal user code (set and unset) but the manual I have shows that there is at least 7 different codes!?!!? I have no other codes On the pcb board there is no nvm reset pins like previous alarms ?!? Any help would be great Tony
breff Posted April 16, 2004 Posted April 16, 2004 If you apply for trade membership and get it, someone can answer you in a trade only forum The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
