whibbs Posted June 27, 2007 Posted June 27, 2007 hi i have fitted a permier 24 panel with a gsm unit to text me after an alarm event is there a way i can get the panel test call me phone every few days i am programing the panel using wintex, i have set the option under coms to test call but this does not work can any one help wayne Wayne Hibbs
breff Posted June 27, 2007 Posted June 27, 2007 Global options, test call every x hours, change from 0 to 48 if you want every 2 days, etc. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
whibbs Posted June 27, 2007 Author Posted June 27, 2007 Global options, test call every x hours, change from 0 to 48 if you want every 2 days, etc. i have set it to 96 every four days is this to long? Wayne Hibbs
breff Posted June 28, 2007 Posted June 28, 2007 Entirely up to you mate, its your phone bill. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
whibbs Posted June 28, 2007 Author Posted June 28, 2007 Entirely up to you mate, its your phone bill. have set the panel to test call but for some resaon but it does not call at all does any one have any ideas ? Wayne Hibbs
breff Posted June 28, 2007 Posted June 28, 2007 What happens when you send a manual test call? The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
whibbs Posted June 29, 2007 Author Posted June 29, 2007 What happens when you send a manual test call? all works well no probs at all just can not get it to auto test call Wayne Hibbs
