Vcl Dome
G0GMK
Guys, I know this is a bit of a 'pet' subject but.... I have 'won' a VCL dome which will be used as part of my Amateur Radio station on 23cms. I 'assumed' it would use VCL protocol but seems not. The board is silk screened as VC415/3 and has one 8 way dil switch (address) and one 0.1" header for RS485 termination.
There is a product code label which says VC8E-12AFMP.
I have tried VCL at 9600 and Pelco at 4800. I have tried the address at actual, +1 and -1 but no joy.
Anyone familiar with these ??
Is the address switch only for address ??
Any 'clues' would help
Thanks,
Dave
  • 1 month later...
IIRC VCL domes are addressed as normal binary plus 1
hope this help, if i am right
You will need to set the dip switches to all off for camera one. this is actually number 0 in usual binary but VCL has a weird set up!!!!
and dont forget the refresh the dome after changing the switchers ;-0 i mean turn it off then turn it on again
Please read the forum rules on advertising before reposting you signature. also your image is far to big.
