Pir In Bathroom
cjay
Hello,
I've never installed a PIR in a bathroom before. Has anyone had any experience of this? Is it advisable or not?
Guest Dave the alarm man
wet room, no
Hello,
IMO, No.
due to steam ect. fit a contact on the window.
will that not also corrode after time though?
sealed contact clever clogs :P
and even if it did, much better then a powered device due to fuses ect.
and yes IP rated jb.
wet room, no
contact the internal door of the bathroom smc out side the room.
ground floor bathroom? A 3 lever lock on the door (when out) may be an idea
I assume like my bathroom there nowt worth nicking unless you've got that really posh bog roll?
wet room, no
it is fine to contact the window in the means i have described.
if you contact the door what will they do at night? omit it and be unprotected?
maybe, or tunstall zone omit module either on timer or controled by chubb lock :P
sub curls one out or the mirror steams up so they open window what happens then smarty pants?
