Pickers4567 Posted June 30, 2007 Posted June 30, 2007 Hi, I have been having problems with the controls of my Optima Compact. The buttons on the control panel and main box were not working, so I opened the main box causing the tamper alarm to go off. Once the alarm goes off, the buttons begin to work to allow me to disable the alarm. However. once the alarm has been disabled the buttons no longer work and the tamper light is showing. Please help.
alterEGO Posted June 30, 2007 Posted June 30, 2007 Hi,I have been having problems with the controls of my Optima Compact. The buttons on the control panel and main box were not working, so I opened the main box causing the tamper alarm to go off. Once the alarm goes off, the buttons begin to work to allow me to disable the alarm. However. once the alarm has been disabled the buttons no longer work and the tamper light is showing. Please help. is the control panel lid in place when you try to use a button?
Pickers4567 Posted June 30, 2007 Author Posted June 30, 2007 is the control panel lid in place when you try to use a button? No - It was before I took it off and they didnt work then.
camerabloke Posted June 30, 2007 Posted June 30, 2007 it means there is a tamper on the system some where ie bell , detectors , panel Eucam Security Systems 0845 4630 746 www.eucam.co.uk
Pickers4567 Posted June 30, 2007 Author Posted June 30, 2007 Sorry - the buttons only stop working after I press reset. But pressing the buttons prior to this doesn't let me enable the alarm.
camerabloke Posted June 30, 2007 Posted June 30, 2007 still means a tamper fault though Eucam Security Systems 0845 4630 746 www.eucam.co.uk
alterEGO Posted June 30, 2007 Posted June 30, 2007 Sorry - the buttons only stop working after I press reset.But pressing the buttons prior to this doesn't let me enable the alarm. after pressing reset is the lid still off?
Guest Dave the alarm man Posted June 30, 2007 Posted June 30, 2007 it won't work with lid tamper open
Pickers4567 Posted June 30, 2007 Author Posted June 30, 2007 I have put the lid back and the buttons are working. However when I now key in the code and press set I do not get the countdown to be able to leave the house.
camerabloke Posted June 30, 2007 Posted June 30, 2007 sound like it has defaulted back to factory settings then Eucam Security Systems 0845 4630 746 www.eucam.co.uk
