Fire Alarm After Lightning
Hi
im new to this
i have been asked to look at a fire alarm panel that has zone 3 in fault all the time
its in a building that had its earth rod hit by lightning this afternoon (colleager saw the lightning hit the earth rod), the building is a house with 2rooms converted into an office at home
ne ideas on what to do
its a 4 zone panel,moved zone 3 wiring to zone 4. and works fine
moved the end of line resistor from the spare zone 4 to zone 3, but cant clear the fault on zone 3
all detectors work fine with smoke can
all call points work fine with test key
zone 1: downstairs call points
zone 2: upstairs call points
zone 3: smoke detectors
zone 4: spare
any ideas on whats wrong?
baz
When you said you moved the end of line unit from zone 4 to zone 3, was that with the circuit cables removed, with the end of line unit connected direct into the panel?
zone 3 had about 4 detectors and 4 call points wired with an eol reistor and was in fault
zone 4 just had an eol resistor
moved the resistor from 4 to 3
moved detecotrs + cp's and eol from 3 to 4
zone 4 works fine now
zone 3 still in fault
im thinking the board is fried
id like to see them fit addressible system hehe but need to see if i can fix it for them first as there is no support contract on the system)
It sounds like the lightning has blown the fault monitoring it is a common
problem after a strike.
New panel needed now
Pete
Peter Robinson
Freelance
M:07889038650
grrr
see if i can sell them my 12 zone hehehehe
and make a profit! hehe
the fault monitoring for all the other zones + the sounders still work fine
baz
