Guest darren1907 Posted April 17, 2004 Posted April 17, 2004 Hi all - just registered with the site hoping someone can help me with my problem. I decided to install an alarm system in my house myself, now to my problem, I bought an Accenta 8 control panel off Ebay and after installing and powering I realise that it wont accept any of the default codes - I have tried to contact the seller without success, is there a way I can reset the unit to its factory default settings? Any help would be greatly appreciated - thanks
Guest alarm man Posted April 17, 2004 Posted April 17, 2004 try the ade website you should be able to get a manual on it that tells you in it how to do it . www.ade.co.uk
Guest darren1907 Posted April 17, 2004 Posted April 17, 2004 Thanks for the info. the procedure I needed was here and the problem is now solved -
