Hawksecurity Posted July 4, 2007 Posted July 4, 2007 just wondered if anyone else has had the same problem as i just have with a scanronic 500r (radio) panel will not provide a adequate negative trigger to operate a sd1 dialer.... or is it just that the dialer is faulty?
Guest Dave the alarm man Posted July 4, 2007 Posted July 4, 2007 just wondered if anyone else has had the same problem as i just have with a scanronic 500r (radio) panel will not provide a adequate negative trigger to operate a sd1 dialer.... or is it just that the dialer is faulty? don't like dialers, whoever what else is of the same output? shed loads???? switch a relay of the sab otput, using the aux neg instead bobs your uncle?
