Garden Office Alarm Help!
tpj
Hi, I have a garden office which I need alarming, ideally I would like a remote keypad by the door, 1 PIR, a door contact and maybe a panic button. I also want it so that I can have it alarmed while i'm inside (PIR off).
I was thinking of this maybe? http://www.tlc-direct.co.uk/Products/TSACMG4.html
Im on quite a tight budget while refurbishing so
Guest BellMan371
:no:
1st because it in an outdoor building so comes under part p
and second because it could be unplugged and forgotten about, so it is not advisable to put on a plug.
Would it be ok with a battery back up, when i say garden office its my study - no employees so forget part p!
Guest Dave the alarm man
part applies to dwellings
you cant forget Part P.
its the law :unsure:
Eucam Security Systems
0845 4630 746
www.eucam.co.uk
Whats the point in having it set while you are in?
With the pir off only the final ext door would be set??
If the door is opened it would only cause the EE timer to start.
But if you want to fit a flood light outside to light up the garden, put it on a plug top, no Part P !! Work that one out.
Guest BellMan371
Domestic Installer Scheme (Part P)
The Domestic Installer Scheme is the NICEIC approval for contractors undertaking work within the scope of Part P of the Building Regulations.
What is the Domestic Installer Scheme?NICEIC
Growing old is mandatory, growing up is optional
