Paragon Plus - No Bell
Hi all,
Just after some expert advice. I have a paragon plus which seems to work other than the bell which does not sound. There is a box on both the front and back of my house. Running the test mode should sound the bell but again it fails. There is no fault light to indicate a bell fuse blown.
Any experts have any ideas what it could be and the likely damage?
Rob
id say depending on age of system could be a bell box fault itself.
Go on then i have to ask, lets say it is, guy comes goes up fixes/changes it ball park figure?
thanks so much to all
Rob
it may be simple fix. but if it is knacked 80-100 quid ball park
Ohnot so bad then. Many thanks for all your help, will let you know what it was
Rob
Guest anguscanplay
Rob
Ive got a few dozen left to change since the storm but if your nearer sheffield than barnsley send me a personal message and i`ll return it with contact details
Angus
