johnstone43 Posted July 11, 2007 Posted July 11, 2007 Hi everyone Just wondered if anyone has any ideas on solving this problem. I have a steady signalling light showing .....................continually. Tried full set, part set, changing all the PIR batteries etc to no avail.
Guest anguscanplay Posted July 11, 2007 Posted July 11, 2007 Hi everyoneJust wondered if anyone has any ideas on solving this problem. I have a steady signalling light showing .....................continually. Tried full set, part set, changing all the PIR batteries etc to no avail. i had heard that this was a very good panel , seems not , is it saying that the signal is been blocked, lost or overpowered jammed etc ?
morph Posted July 12, 2007 Posted July 12, 2007 Hi everyoneJust wondered if anyone has any ideas on solving this problem. I have a steady signalling light showing .....................continually. Tried full set, part set, changing all the PIR batteries etc to no avail. I owuld be looking for whats changed in or arround your house, unfortunately with a radio system a lot can effect it, without getting an engineer in to check the system and doing a new radio survey, its going to be hard to diagnose the fault. Best advice get the installer back in.
