Question About K9-85 Walktest.
Dandle
Hi all, I have a simple question for you guys in the know but I cant find an answer for it.
I have run wires in my house now for my premier 24 panel(not fitted yet) which will be wired to 5 K9-85 pet friendly pirs. I have wired the sensors I have fitted as EOL. The sensors have an option for a walktest to be wired up to the control panel and the sensor then has a jumper selection "via test". The premier 24 doesnt have a walktest connection.
So my question is do I leave the jumper in "walktest" rather than "via test"? and assuming I do as I cant find any info in either the sensor installation or control panel instructions to remove it, will the led light all the time when the sensor is triggered even with the alarm disarmed?(or do i remove the jumper to stop the led flashing?).
Thank you for any help.
