pieterv Posted July 15, 2007 Posted July 15, 2007 Hi, Just moved into new home that has a Veritas 8 or R8 (not sure which) alarm system. By mistake I set off the tamper alarm by opening the main box (didn't know what it was, thought it might be cable so wanted to check). Since then the entrance hall PIR sets off the alarm even when it is unset (green led constantly on). Any ideas what I could do about that? Thanks for any replies. Pieter
Guest anguscanplay Posted July 15, 2007 Posted July 15, 2007 Hi,Just moved into new home that has a Veritas 8 or R8 (not sure which) alarm system. By mistake I set off the tamper alarm by opening the main box (didn't know what it was, thought it might be cable so wanted to check). Since then the entrance hall PIR sets off the alarm even when it is unset (green led constantly on). Any ideas what I could do about that? Thanks for any replies. Pieter you mean it goes of - or does it make a " chime " noise , if its the latter you may have turned the chime on in error - turn that curcuit off chime if not did you have a fault before you interfered with the panel , and is it a new house or just new to you Angus
pieterv Posted July 15, 2007 Author Posted July 15, 2007 Hi Angus, Thanks for the quick reply. No it is not set to chime, the alarm goes off properly. I checked which zones are set to chime just to make sure, and it is only the main door (zone 1). It is not a new house, just new to me. But the probnlem was not there before I opned the case (I know, should have kept my fingers off ). Pieter
alterEGO Posted July 15, 2007 Posted July 15, 2007 Hi Angus,Thanks for the quick reply. No it is not set to chime, the alarm goes off properly. I checked which zones are set to chime just to make sure, and it is only the main door (zone 1). It is not a new house, just new to me. But the probnlem was not there before I opned the case (I know, should have kept my fingers off ). Pieter only thing i can think is it is some how been proged as panic
Guest anguscanplay Posted July 15, 2007 Posted July 15, 2007 Hi Angus,Thanks for the quick reply. No it is not set to chime, the alarm goes off properly. I checked which zones are set to chime just to make sure, and it is only the main door (zone 1). It is not a new house, just new to me. But the probnlem was not there before I opned the case (I know, should have kept my fingers off ). Pieter which zone number is the hall - maybe the system has rebooted - power cut lately ? do yourself a favour and get a guy in to sort it -
pieterv Posted July 15, 2007 Author Posted July 15, 2007 which zone number is the hall - maybe the system has rebooted - power cut lately ? do yourself a favour and get a guy in to sort it -
