haveago Posted July 16, 2007 Posted July 16, 2007 I installed an Accenta8 a littel while ago and had a power problem to the house recently. The kpd stopped working but was still backlit so looking in the forum I saw that it could be related to battery; hence replace the battery. Had a spare kpd which I also replaced. However, during the resetting due to complete power loss I tried re-commissioning and all seemd to be going OK. When I try to set the full set or partial set it always sets the alarm off and points at Zone1 on the kpd. Zone1 is the EuroViper detector which I also replaced (had a spare) but can't remember what the settings on the dip switches was. So can anyone help - using 6core wiring.
spider Posted July 16, 2007 Posted July 16, 2007 I installed an Accenta8 a littel while ago and had a power problem to the house recently. The kpd stopped working but was still backlit so looking in the forum I saw that it could be related to battery; hence replace the battery. Had a spare kpd which I also replaced. However, during the resetting due to complete power loss I tried re-commissioning and all seemd to be going OK. When I try to set the full set or partial set it always sets the alarm off and points at Zone1 on the kpd. Zone1 is the EuroViper detector which I also replaced (had a spare) but can't remember what the settings on the dip switches was. So can anyone help - using 6core wiring. The position of the dip switches wont make that much difference, they are for LED enable and double knock, maybe the viper is u/s , try shorting out the viper to check the system sets ok
haveago Posted July 17, 2007 Author Posted July 17, 2007 Thanks for the reply, but I'm a novice - how do I short the Viper without removing the wiring from the control panel ?
Guest anguscanplay Posted July 17, 2007 Posted July 17, 2007 Thanks for the reply, but I'm a novice - how do I short the Viper without removing the wiring from the control panel ? we cant really tell you that im afraid now can we
FASTCAR Posted July 18, 2007 Posted July 18, 2007 Check that you have power to the viper..does it light up when tapped?.You could have blown a fuse when swopping the rkp or the viper.
haveago Posted July 19, 2007 Author Posted July 19, 2007 Yes, the Viper has power OK. The red light flashes continuously untill I go to Service Mode then it stops. After I go back to day mode the light doesn't come back on again until I either tap the viper or open the door - it then flashes continuously again.
Guest anguscanplay Posted July 19, 2007 Posted July 19, 2007 Yes, the Viper has power OK. The red light flashes continuously untill I go to Service Mode then it stops. After I go back to day mode the light doesn't come back on again until I either tap the viper or open the door - it then flashes continuously again. thats right then so have you messed up the cable , have you proved the viper relay even works , have you got a short between poles or between volts and pairs?
alterEGO Posted July 19, 2007 Posted July 19, 2007 thats right then so have you messed up the cable , have you proved the viper relay even works , have you got a short between poles or between volts and pairs? unless its the old style and is latching on with out resetting?
BASS Posted July 19, 2007 Posted July 19, 2007 thats right then so have you messed up the cable , have you proved the viper relay even works , have you got a short between poles or between volts and pairs? The person is looking for some help not sarcastic know it all answers. If you can't help then please keep your comments to yourself this forum is for helping people with constructive answers. Dave
Guest anguscanplay Posted July 20, 2007 Posted July 20, 2007 The person is looking for some help not sarcastic know it all answers. If you can't help then please keep your comments to yourself this forum is for helping people with constructive answers. Dave sorry Dave i dont get where your coming from with that comment ( possibly you misread my post ? ) so I will repeat my question - have you messed up the cable GOT THE COLORS THE WRONG WAY , have you proved the viper relay even works DOES IT "CLICK" WHEN YOU TAP IT , have you got a short between poles or between volts and pairs?ARE ANY OF THE CABLES "TOUCHING " BY MISTAKE you will need a test meter to check the device Angus ( hurt my feelings he did )
