Intellisense St802
Thanks for the response I got concerning st802 user manual. I have followed the instructions but it seems as if no zone is programmed to be isolated. It triggered on every zone at Night set and home set. I do not even know the zone numbers since I was left with no instruction.
PLEASE HELP OUT.
STEPHEN
Guest anguscanplay
PLEASE HELP OUT.
STEPHEN
hi Stephen - if i could save you a lot of time and refer you to this thread from yesterday
if it needs part sets programing ?
Do a walk test (Code *94) to Identify the zones
Then if say zone 6 is the landing
You can do a manual isolation (Code *6)
You may have a problem unsetting if a zone on entry is not programmed correctly
Sounds like no parts sets are programmed
unfortunatly this would have to be done by an engineer through the system programming
