Texecom Premier 24 Pannel
LED
Hi can any one help
My chime facility doesn't seem to work. I have programmed it in the attributes to accept chime 1 on one of my door magnet Zone 7.
Guest Dave the alarm man
have you turned it on too?
Hi Dave
not sure what you mean here. Do you have to assign it within the programming menu. I thought it was turned on within the zone set up area within the engineering facilities.
Hi Dave
asigned zone by zone, but you have to turn chime on ;) press the chime button when in day
Many thanks Dave
It's working fine now. I found the instructions within the Master users file. Fancy that just the chime button...
cheers LED
