Scantronic 660 & 9651
mikenash
Help
I have just purchase the scantronic 9651 Panel and a 660 speech dialer
does anybody now how to connect the dialer to the panel via the comms plug
ie what colour wires go in which terminal on the dialer
ie red = +12
blk = 0V
etc
I have not installed the panel as yet just want to make sure i get it correct before i rip out my //.Large National Installer.// system !
Thanks Mike
Guest anguscanplay
Help
ie red = +12
blk = 0V
etc
Thanks Mike
Hi mike - what does it say in the instructions ?
Angus
Angus
on the dialer (660)
OP1 =programable output (active +12v)
LF= Telephone line fail output (active +12v)
0V = 0v supply
12V = +12v supply
ST4 = +ve removed
ST3 = +ve applied
ST2 = +ve applied
ST1 = +ve applied
ST+ = +ve removed
then it says connect the inputs reqd For guidance fire ST1 panic ST2 burg ST3 spare ST4
on the panel (9651)
comms plug =
O/P1 = brown -ve applied( +ve removed) in alarm
O/P2 = orange -ve applied (+ve removed) in alarm
O/P3 = yellow -ve applied (+ve removed) in alarm
O/P4 = green -ve applied (+ve removed) in alarm
O/P5 = blue -ve applied (+ve removed) in alarm
O/P6 = purple -ve applied (+ve removed) in alarm
O/P7 = white -ve applied (+ve removed) in alarm
O/P8 = grey -ve applied (+ve removed) in alarm
line fail input = white/brown +12v applied to indicate tel line fail
Tell Black input = white/orange +12v applied to chage from engineer to customer reset
0V = black
12V = red
hope the above helps / as you can see i seem to have move wires than connections and the 2 sides arn't labeled the same
if possible (looks like it can be done in manual) i would like to make it so if its a fire / burg / panic the dialer will recognize the signal
mike
Guest anguscanplay
you have 8 outputs from the panel but only four inputs to the dialler that is correct just isolate the outputs you dont need then once you have programmed the outputs to be the type you want ( but it might well be the default settings anyway ) your sorted forget colors just connect output to input ie output 2 to ST2 etc but remember it all changes round for the LF - easy
Angus
Angus
I think I get the fist bit but what do you meen it changes round for the LF
LF = line fail i presume
so just to check
12v to 12v
0v to 0v
op1 to st1
op2 to st2
op3 to st3
op4 to st4
LF to line fail input = white/brown +12v applied to indicate tel line fail
what happens to op1 & st+
mike
Hold on........................according to those instructions the panel outputs are positive removed but the dialler inputs are positive applied, if so it wont work except for ST4
Guest anguscanplay
nah its classic scantronic double talk - zones not selected will be removed lol
positive applied at the 660 means in its un-triggered state and positive removed at the panel is triggered
think I read in instuctions you can program the outputs to + or - ve
will check and report back (cooper/scantronic said the kit is all compatable with each other)
Guest anguscanplay
try it either way - youll soon find out lol - expensive to call mobiles ?
anugs going back to what I said will it work if its wire how i said
and what happens to spare connections
