Mike123 Posted July 20, 2007 Posted July 20, 2007 hello everybody - hoping someone can help I have what I beleive to be a scantronic 9800 system here (at least the input panel is) the mains transformer has failed (shorted turns on the primary as it smokes ) and I need to know what voltage and current output it was(it only has a single winding on the secondary) and it's fitted with four long screws through the corners of it. No label or marking on it though ? Can any kind soul help with details ?
Guest anguscanplay Posted July 20, 2007 Posted July 20, 2007 hello everybody - hoping someone can helpI have what I beleive to be a scantronic 9800 system here (at least the input panel is) the mains transformer has failed (shorted turns on the primary as it smokes ) and I need to know what voltage and current output it was(it only has a single winding on the secondary) and it's fitted with four long screws through the corners of it. No label or marking on it though ? Can any kind soul help with details ? have a look at the bottom of the PCB in between the heatsink and the battery terminal - is the bank of diodes still there / browned out ? if it looks "wrong " the chances are just changing your transformer won`t be enough and it may be quicker/ easier to replace the whole control gear Angus ( see i`m been helpful huh )
black knight Posted July 20, 2007 Posted July 20, 2007 have a look at the bottom of the PCB in between the heatsink and the battery terminal - is the bank of diodes still there / browned out ? if it looks "wrong " the chances are just changing your transformer won`t be enough and it may be quicker/ easier to replace the whole control gear Angus ( see i`m been helpful huh ) ok what have you done with the real angus p THE BLACK KNIGHT "Any comments / opinions posted are my opinion only and do not represent those of my employer or Company."
Guest anguscanplay Posted July 20, 2007 Posted July 20, 2007 ok what have you done with the real angusp pmsl - no really, pmsl
Mike123 Posted July 23, 2007 Author Posted July 23, 2007 I do brown good repais for a living , I would be checking the PSU components after I have replaced this TX the TX is definitely stuffed as I disconnected the secondary to test and smoke still belched from the TX
Guest Dave the alarm man Posted July 23, 2007 Posted July 23, 2007 buy an endstation of fleabay & rob it out of that, or treat youself to some new controls......
