Part Set Problem
MickH
Hi can anyone help please?
I installed the following as a DIY project several years ago.
I have an Accenta G3 Panel, IntelliSense IS-215T PIR
Guest Dave the alarm man
issues with the new rkp's on thinks?
Have today removed all connections to the new RKP and wired back in the original key pad, 6 staight forward connections.
Tried to programme part set with this one key pad but the same problem is still there.
Go into enginner mode, press Prog button to set up program and the TAMPER and ATTACK led's light up, when according to the manual, only the ATTACK led should light up.
Any help with this problem is very much wecomed,
Thanks, MickH :hmm:
Thanks, MickH :hmm:
did 1, 2 and 3 also light up?
right for the product?
BTW press PROG them same lights come on??
Have you tried just carrying on with the programing?
Hi Tinnitus, yes have continued through the whole prog numerous times with no succsess. If it was a TAMP wiring problem surely I would not be able to set/unset in normal operating mode which works fine.
When you get to the part of the prog where you have to select the zones you wish to omit for the part set, which is 2 and 3, I assume these zones have to be deselected. Thanks for your advice.
Hi Dave excuse my ignorance but what does BTW stand for.
MickH.
are you sure you have the right eng number? are you sure you are in eng mode?
p.s. dont tell us how you got into eng mode in the public forum
Multiple choice, & no you can't phone a friend.....
A.) Big T*tted Wife
B.) Bald Taffy W*nker
C.) Bog, Toilet, Watercloset
D.) By The Way
yes I have the right eng number as I have reset everything back to the factory default settings and am using default numbers.
