John Posted July 21, 2007 Posted July 21, 2007 Hi all, A customer has a credit card machine on his phone line which is stopping a dialler from working. It works fine when cc machine is not connected. Does he need a seperate line for his dialler or is there a workaround??? Filter etc? As you can see, I know sodall about telecoms, so any help would be much appreciated. Fire Member
tinnitus Posted July 21, 2007 Posted July 21, 2007 Hi all,A customer has a credit card machine on his phone line which is stopping a dialler from working. It works fine when cc machine is not connected. Does he need a seperate line for his dialler or is there a workaround??? Filter etc? As you can see, I know sodall about telecoms, so any help would be much appreciated. you could try the ADSL filter, i think the card machine uses a higher frequency and the filter just splits the two.
luggsey Posted July 21, 2007 Posted July 21, 2007 Hi all,A customer has a credit card machine on his phone line which is stopping a dialler from working. It works fine when cc machine is not connected. Does he need a seperate line for his dialler or is there a workaround??? Filter etc? As you can see, I know sodall about telecoms, so any help would be much appreciated. Some CC machines dial out on demand, some are connected 24/7, make sure you know which sort you have before looking for a fault? Hello Tinnitus my old sparring partner! How do you like your new leader? Goad goad...... ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
