Bazz1977 Posted July 22, 2007 Posted July 22, 2007 Hi all i have a Gardtec 595 i am trying to add a 8 zone wireless expander but am have great trouble. I think i may be wiring the 485 bus connection wrongly but not sure I have gone from panel to interface card on serial cable then from interface card with 4 core to zone expander but every time i try to install zones it says wireless reciever not active please help
Alarm Protection Posted July 22, 2007 Posted July 22, 2007 Hi all i have a Gardtec 595 i am trying to add a 8 zone wireless expander but am have great trouble. I think i may be wiring the 485 bus connection wrongly but not sure I have gone from panel to interface card on serial cable then from interface card with 4 core to zone expander but every time i try to install zones it says wireless reciever not active please help The 595 has a connection on the back of the circuit board(newer ones are 4 pin) This expander cable goes from board to expander. Then its into programming and the instructions that come with the expander tell you how to do it. !
Bazz1977 Posted July 22, 2007 Author Posted July 22, 2007 Thanks for help I have used plug on connector from rear of panel to interface module using the 04-070 serial cable then from interface module to expander connecting the Bus Connections but when i go to add wireless zones it says Receiver 1 not responding Any ideas were i get a wiring diagram or full install manual
arfur mo Posted July 23, 2007 Posted July 23, 2007 Thanks for help I have used plug on connector from rear of panel to interface module using the 04-070 serial cable then from interface module to expander connecting the Bus Connections but when i go to add wireless zones it says Receiver 1 not responding Any ideas were i get a wiring diagram or full install manual later versions of the G595 i believe, do not require the interface anymore they connect direct (as per the panlel drawing in the quick start guide). regs alan If you think education is difficult, try being stupid!!!!
Alarm Protection Posted July 24, 2007 Posted July 24, 2007 Have you switched the Zex on in the programming??? !
Guest anguscanplay Posted July 24, 2007 Posted July 24, 2007 i had this recently - the manual said the old connections but the pcb had the rs port
arfur mo Posted July 25, 2007 Posted July 25, 2007 i had this recently - the manual said the old connections but the pcb had the rs port i wonder if he has checked the battery? lol (sorry Bazz it's an 'in' joke, Angus is our battery 'Mod' ). i bet you (Angus) had a panel where they run out of the newer instructions so stuck in old stock, anyway the tech help number is on the back so give them a call be quickest as it also depends on the version number of the software. regs alan If you think education is difficult, try being stupid!!!!
tinnitus Posted July 25, 2007 Posted July 25, 2007 Hi all i have a Gardtec 595 i am trying to add a 8 zone wireless expander but am have great trouble. I think i may be wiring the 485 bus connection wrongly but not sure I have gone from panel to interface card on serial cable then from interface card with 4 core to zone expander but every time i try to install zones it says wireless reciever not active please help you definately need to use the blue 4, maye 5 pin connector on the rear of the pcb. i know this as i cut it off and tried to wire it into the data line! i had to use a galaxy digi cable to make it work. the newer ones come with an expander already connected i think.
alterEGO Posted July 25, 2007 Posted July 25, 2007 you definately need to use the blue 4, maye 5 pin connector on the rear of the pcb. i know this as i cut it off and tried to wire it into the data line! i had to use a galaxy digi cable to make it work. the newer ones come with an expander already connected i think. ???????? expander already connected to the pcb???????????don't think so.
tinnitus Posted July 25, 2007 Posted July 25, 2007 ???????? expander already connected to the pcb???????????don't think so. via cable, might be output expander. maybe i got one another had "put back"
