Need Help Wiring Speech Dialler
b21playa
Hi all
Successfully firtting my alarm panel and today I came to fit the dialler. I have a veritas R8 panel and purchased a Texecom dialler.
Looking through the manual, I see that the R8 has a negative trigger for input 3 on the dialler. So I ran a 6-core cable from panel to dialler.
Panel__________ Dialler
aux+ ________ 12v
Aux - _______ 0V
B _________ Trigger 3
Tamp ____________ Tamp
I have used the dialler test operation and it tries to call person. However when the alarm goes off, nothing happens and the dialler displays "Ready".
Am I missing something, it seems the dialler is not being triggered
Many Thanks
  MrIPFreely said:
just a couple of observations
why have you used trigger 3?
have you set trigger 3 up to dial out. ie is there a trigger 1 or 2? if so try using trigger 1
used trigger 3 as i saw something in the manual.
I have tried trigger 1 and the same.
I will in the morning, connect back to trigger 1.
should it be negative applied or positive applied?
