Need Help Wiring Speech Dialler
b21playa
Hi all
Successfully firtting my alarm panel and today I came to fit the dialler. I have a veritas R8 panel and purchased a Texecom dialler.
Looking through the manual, I see that the R8 has a negative trigger for input 3 on the dialler. So I ran a 6-core cable from panel to dialler.
Panel_______ Dialler
aux+________12v
Aux -_______0V
B__________ Trigger 3
Tamp_______ Tamp
I have used the dialler test operation and it tries to call person. However when the alarm goes off, nothing happens and the dialler displays "Ready".
Am I missing something, it seems the dialler is not being triggered
Many Thanks
Hi all
aux+________12v
Aux -_______0V
Tamp_______ Tamp
Many Thanks
hi b21playa
are you fully activating you alarm system?, the external siren only sounds on a full alarm, so if your simply tripping a tamper while unset, or setting off your system via the entry timer then the siren output will not change state until the second timer times out.
there is an option in the dialer programming to cancel calls on a restored input, so if you accidentally trip your system then turn it off you key-holders are not then disturbed - have you turned this option on?
if so sounding the sirens then canceling will cancel the dialer signal, so try using the external 'bell test' option (needs a master code) or press a panic button if you have one to eliminate this 'error' possibility and allow enough time for the call to complete.
you may have to fit a pull up bias resistor to give a clean switched signal, your equipment supplier's tech help should advise you how and what value is needed.
and just before i'm jumped on, this panel has i believe a dedicated output to be used for remote signaling transmitters going to ARC's, but there are operational ramifications such as 'confirmed signals' to confuse the issue for speech dialers, so in your installation the bell output is favorite's for simplicity imo.
regs
alan
hi b21playa
regs
alan
hi Alan
Im using the panic function of the panel and holding down 3&9 simultaneously.
Should it be set to negative applied or positive applied?
hi Alan
your panel's siren output will got fully negative when in full alarm or bell test, check with a meter you have 10 - 12+ when not activating, some panels do have a low + voltage which when it changes state is not a 'clean' enough transition so you need to fit a 'pull-up' biasing resistor from BELL+ (standing 12 volts) to BELL- 1.8k ohms @ 1/2 watt should do it.
regs
alan
