rory Posted August 9, 2007 Share Posted August 9, 2007 Hi, hope there is someone out there that can help..................i was doing some electrical work at home and had to switch the main supply off. The alarm system obviously displayed mains fault,,,,,,,,,,,,,,,, But Im now getting message on the keypad disply nd-NO PANEL DATA,,,,,,,,,,,,,,,,and now it wont take any comands.... is there somw way I can reset this?????? Link to comment Share on other sites More sharing options...
arfur mo Posted August 9, 2007 Share Posted August 9, 2007 Hi, hope there is someone out there that can help..................i was doing some electrical work at home and had to switch the main supply off. The alarm system obviously displayed mains fault,,,,,,,,,,,,,,,, But Im now getting message on the keypad disply nd-NO PANEL DATA,,,,,,,,,,,,,,,,and now it wont take any comands.... is there somw way I can reset this?????? not a known panel to me, but classic standby battery failure symptoms imo if you are competent with safe working on 240 volt powered equipment (and be warned confidence is handy but no substitute) you could replace the rechargeable battery in the main panel, power down the system completely restore mains then battery entering code if sirens sound. but i'd recommend an engineer to service the system and check the fault out properly and safely. regs alan If you think education is difficult, try being stupid!!!! Link to comment Share on other sites More sharing options...
camerabloke Posted August 9, 2007 Share Posted August 9, 2007 you've check to make stuff one one's pinched the panel? have you checked if you have learnt english? Eucam Security Systems 0845 4630 746 www.eucam.co.uk Link to comment Share on other sites More sharing options...
jnealon Posted August 9, 2007 Share Posted August 9, 2007 Check that the wiring to the keypad is correct and that the dip switches are in the correct position. www.realsecurity.ie Link to comment Share on other sites More sharing options...
Stal. Posted August 9, 2007 Share Posted August 9, 2007 Hi, hope there is someone out there that can help..................i was doing some electrical work at home and had to switch the main supply off. The alarm system obviously displayed mains fault,,,,,,,,,,,,,,,, But Im now getting message on the keypad disply nd-NO PANEL DATA,,,,,,,,,,,,,,,,and now it wont take any comands.... is there somw way I can reset this?????? *************************************************** Hope this helps. Defaulting information removed. UTC - The dawn of a new era ! Link to comment Share on other sites More sharing options...
Guest anguscanplay Posted August 9, 2007 Share Posted August 9, 2007 *********************************Hope this helps. wont that reboot it ? Link to comment Share on other sites More sharing options...
Stal. Posted August 10, 2007 Share Posted August 10, 2007 wont that reboot it ? Yes, but that's the way in the past that i've got it to work. The cs350 is a 6 zone panel so it would only take 5 mins to reprogramme ! UTC - The dawn of a new era ! Link to comment Share on other sites More sharing options...
Guest anguscanplay Posted August 10, 2007 Share Posted August 10, 2007 Yes, but that's the way in the past that i've got it to work. The cs350 is a 6 zone panel so it would only take 5 mins to reprogramme ! sure but your a top engineer - with manuals and everything lol Link to comment Share on other sites More sharing options...
Stal. Posted August 11, 2007 Share Posted August 11, 2007 sure but your a top engineer - with manuals and everything lol Ha, ha, 'o how my sides ache UTC - The dawn of a new era ! Link to comment Share on other sites More sharing options...
radiostar Posted August 15, 2007 Share Posted August 15, 2007 Are Aritech panels still going? I have spent ages on google trying to find a distributor or manufacturers website so we can get some manuals. I know nobody posts engineering manuals here, but if you know of a distributor, I would be very grateful. As we only use Gardiner red and Gardiner green, the options are limited. Specifically we are after a programming manual for the CS 450, Blank end and LCD Rkp. which by the look of it must be at least 10 years old. Original installer now relaxing somewhere on the Costa del sunshine and we have been asked to take over this site. May finish up swapping out the panel , however, I always like to try and run with the one they have got for a while before condemming it. Any help would be appreciated. Link to comment Share on other sites More sharing options...
