Concept Alarm System Fault
Angus if it was a panic button pressed in slightly why would the panel be showing tamper like the guy said in the original thread?And if it was the PA button the panel would lock-out until you press the reset button on PA device, plus the panel would say PA wouldn't it?I think without a meter and some knowledge of how to use it your p1ssing in the wind my friend.
Oh, a clever little fellow aren't we.
Edit your post after you pose a question. Lower than a snakes belly.
Growing old is mandatory, growing up is optional
Thought i'd missed all the fun whilst i was away. looks like i came back in time to catch it.
Way to go Saint Angus
Guest anguscanplay
cheers mate - seems Angus`s ability is in doubt , dont tell any of my lads will you lol
:rolleyes:
how do you know the batteries are good ?
Both batteries tested under load
Hi mate is it an ade concept or a concept 3000/4000 fron innerrange.
ade concept
or maybe a panic button is slightly pressed ? go round with a key and give them all a turn - just a suggestion though to be fair your going to need a test meter and a fair amount of knowledge to cure an intermitant fault like the one your describing, my money is still on the battery.Angus ( check it one stage at a time )
Thanks tried PA'S ,when these open circuit they light up attack on keyboard.
Your saying it goes into full alarm when unset (full alarm meaning internal and external bell box going off) if thats the case it sounds like external bell box tamper.If only internal sounder is going off you can sure the tamper exists within the property,ie rkp detector or cabling tamper.I hope this helps.
Thanks already shorted out all tamper circuits
Thanks Tested under load.
you have a tamper fault, if you have linked the global out it could be :BELL TAMPERRKP TAMPERPANEL TAMPERDUFF BATTERY
Thanks ,have shorted out all tamper circuits already.
:rolleyes: Both batteries tested under loadade conceptThanks tried PA'S ,when these open circuit they light up attack on keyboard.Thanks already shorted out all tamper circuitsThanks Tested under load.Thanks ,have shorted out all tamper circuits already.
have you checked the charging circuit is intact, they are known to blow on ade gear.
if it is, your panel is up the creek without one.
ade concept
So when exactly did you do all of th above ??
If it was initially, before posting your question, then why not say so???
I may be wrong but strong suspicion of yet another red herring wind up here.
Guest anguscanplay
me I`m always a sucker for " elderly neighbour " questions - weird as in real life i charge the old people twice as much lol
OMG Have you all got pmt on this site , and no thats not an alarm term?
