Texecom Premier User Code Issue
bigstevex
Something strange happened with my premier 48 this morning,
i set the alarm using my code, but i noticed i'd left a window open, so i sent my better half back in to close it while i started the car etc.
Next minute the alarm went off, the panel wouldn't accept her code, it was asking for her prox tag, which she normally uses but didn't have at the time, thus the alarm went off when the time ran out
Have i done something wrong somewhere when i set it up, we are both set as master users and have our own code and prox tag.
Guest anguscanplay
programed keypad lock out " entry / alarm " ?
If you have prox tags, codes are disabled during entry.
Guest anguscanplay
the score after 90 mins 3 - 0 lol
was that a sarcastic comment against my slow responce?
Thanks for the advice that solves it!
It doesn't lock out the user code that armed it though, i had to enter my code to turn it off as my tag was in the car!
you put your code in after the siren sounded/alarm activated, it will accept the codes at that point but not before, try it again LOL
