visonic installer code
Guest jbhiller
Guest jbhiller
I've seen several posts about having an installer code 'locked out', and the only reply I've seen is that of "change the user code back to 1111 because the user and installer code cannot be the same." However, this is not my case; I tried it just to be safe. I haven't seen anywhere a way to 'reset' to default codes/ settings. Any help would be appreciated.
Guest Peter James
Can you say that again in English?
