Com2400 Audio
tux
Is there a way to hear the com2400 dial? what is the modem level option? i think there is something wrong with this com2400, it can see it because it doesnt say com port 1 fault when its connected but it says no ats available and ats path fault.
Plug a phone in (via an adapter?) and listen? You may need to time taking it off the hook carefully as the com2400 presumably checks for dial tone before dialling.
Guest Dave the alarm man
audio verification board?
modem level is db adjust
if device is not where intended chances are ports set up wrong
New panels and new com2400s dont use com1 anymore and dont need the fly lead, they now use com3.
thanks its working now, should it be sending a text everytime a zone is active when armed
and it seems to stay connected and i have to use the reset digi option to disconnect
b band filter?
I have set a computer up on another line using PageGate software with GetTap and set the SMSC number on the panel to that line so i can see the text messages it is sending without costing 20p a go but it doesnt seem to be working it just hangs on sending text, I successfully sent a message using ActiveXperts SMS and Pager Toolkit SMSC DIalup Demo App so PageGate is working ok, Is there any other software i could try that anyone knows of?
