I Wish I Was As Good As A National
Found this and a lot more, nearly as bad, on a job I'm upgrading at the moment with 17 RIO's and about 86 zones the rest of the system is allot like this but I had to show you this.
IF YOU ARE EASILY OFFENDED LOOK AWAY NOW
(You might have to zoom to see the writing)
Never Teach Your Apprentice Everything You Know
Is that loose, unsleeved strong multi-strand wire just waving about the outer sleeve of an armoured cable!
I'm just an amateur and it looks bl**dy dangerous!
OOH YEH!
There is so much more than this !! :(
Hay that looks alot like the panel i replaced last week. Oh no my mistake that one was on its side with the battery stuck in with double sided tape. :cry:
TVX systems what a good idea by the time the picture had downloaded the intruder would have been long gone.
SFE.Solutions security systems
To-boot 5 of the RIO's on line 1 have a 6 core feeding the data and I cant find the other ends anywhere so they must of stared off some where on the lines
:unsure:
at least the fire cable was a neat job eahy rhino. ;)
At least the mains was done properly, through its own entry point,stuffing gland and cable tie to secure, the rest is shocking!!!! Got to have been a subby!
Less of that matey some of us subbys take pride in our work. Dont tar us all with the same brush.
can you see the cables to the lock above the glass door.Had to remove glass expansion mastic run cables between panels then re mastic also alarm contact for door in shear housing.
