C.S TEK. Posted August 22, 2007 Posted August 22, 2007 OOPS!! I used Marker pen on the battery You really gota be joking that it ruins the batteys, surley the battery will have been changed by the time it rotts through the plastic?? Trade Member As Mr Kingswood said "Dont forget the 6 P's when installing.....Proper Preperation Prevents P*** Poor Performance!!!" John Kingswood(alais Nobby), Paul Earl Ltd 1985-2006
Guest anguscanplay Posted August 22, 2007 Posted August 22, 2007 OOPS!! I used Marker pen on the battery You really gota be joking that it ruins the batteys, surley the battery will have been changed by the time it rotts through the plastic?? lol half and half - it was a flyer from yuasa iirc claimed that marker pen or even the sticky from using insulating tape would degrade the plastic and lead to gas escaping though obviously if you bought there special " battery marking kit " there wouldnt be an issue didnt they once publish a chart with the degree`s over optimum to hours off expected life formula plotted out ( every 5 degrees looses an hour ish ) ive seen to much to take it serious any more Angus ( i scratch it on with my terminal lol ) ps why did it take 5 days to power it up ? lol
alterEGO Posted August 22, 2007 Posted August 22, 2007 not much to worry about anyway, the battery is dated by yuasa and i'm sure others do the same if you can understand it.
Guest anguscanplay Posted August 22, 2007 Posted August 22, 2007 not much to worry about anyway, the battery is dated by yuasa and i'm sure others do the same if you can understand it. banghead
alterEGO Posted August 22, 2007 Posted August 22, 2007 banghead lol, thought you'd like that one matey boy all mine get dated.
C.S TEK. Posted August 23, 2007 Posted August 23, 2007 ps why did it take 5 days to power it up ? lol lol Blame the sparky and customer for handover date change Trade Member As Mr Kingswood said "Dont forget the 6 P's when installing.....Proper Preperation Prevents P*** Poor Performance!!!" John Kingswood(alais Nobby), Paul Earl Ltd 1985-2006
McP Posted August 23, 2007 Posted August 23, 2007 Company I work for was told by NSI Inspector to mark battery with ink marker as heat in panel could cause a label tape/printed to fall off.
whistle Posted August 23, 2007 Posted August 23, 2007 Deveation No Gromit on the 240 Beldon not earthed aswell
magpye Posted August 23, 2007 Posted August 23, 2007 Deveation No Gromit on the 240 I think you'll find that as it is a 'manufactured' cable entry the grommet is not required, cut one with a hole cutter and it is. Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care.
whistle Posted August 23, 2007 Posted August 23, 2007 I think you'll find that as it is a 'manufactured' cable entry the grommet is not required, cut one with a hole cutter and it is. I think you will find for 240 it must have a gromit. Low voltage stuff is ok without a gromit if its a 'manufactured' cable entry.
