I Wish I Was As Good As A National
I think you will find for 240 it must have a gromit.
Low voltage stuff is ok without a gromit if its a 'manufactured' cable entry.
Ok, stand corrected, unless someone knows different ......
OOPS!! I used Marker pen on the battery :no:
You really gota be joking that it ruins the batteys, surley the battery will have been changed by the time it rotts through the plastic?? :hmm:
Neat, but please tell me you haven't used a common zone terminal as the neg for your detector power :bruce_h4h:
Trade Member
Guest Dave the alarm man
BS said every cable which passes though metal entry requies grommet
Battery label with date into stock & fitting date is the norm or is it?
Guest anguscanplay
magpye your not corrected - manf holes DONT need a grommet and any one who argues otherwise can take it up with our NSI inpector
Picking myself up off the floor, going for a stiff drink, thanks angus, I think?
Guest anguscanplay
nah mate , when your right your right lol
Nothing wrong with that on this panel, if anything he should of spread his positives as well ( one per four zones) and the neg of the two zones sharing a com should be wired into their com ;)
Never Teach Your Apprentice Everything You Know
Guest anguscanplay
right , big house on first week in Sept. will take some piccys and show you newboys how it should be done , got far too many of the subby letting me down but none of my own work - keep your eyes peeled lol
Company I work for was told by NSI Inspector to mark battery with ink marker as heat in panel could cause a label tape/printed to fall off.
but then would that not make the battery fall under part 'P' regs while the ink was wet?
lol!
regs
alan
Guest anguscanplay
why date into stock ?
