Logical89 Posted August 21, 2007 Posted August 21, 2007 I've been given an assignment to do a wiring diagram for a RedCare classic onto a G3. I've never installed a RedCare. I need to know in what output terminals on the G3 do i connect the RedCare to for the 2- PA 3- Int. 4- Set 5- Omit 6- Tech 7- Conf I know for the G2 you need an trigger lead kit but i have been told this is not the same for G3's.. It would be most appreciated if someone could help me out with this ASAP. , Nick.
camerabloke Posted August 21, 2007 Posted August 21, 2007 wire the redcare to the galaxy outputs direct then program correct outputs ie 1001 = PA =neg/pos applied = latch/reflex etc Eucam Security Systems 0845 4630 746 www.eucam.co.uk
Guest anguscanplay Posted August 21, 2007 Posted August 21, 2007 I've been given an assignment to do a wiring diagram for a RedCare classic onto a G3.I've never installed a RedCare. I need to know in what output terminals on the G3 do i connect the RedCare to for the 2- PA 3- Int. 4- Set 5- Omit 6- Tech 7- Conf I know for the G2 you need an trigger lead kit but i have been told this is not the same for G3's.. It would be most appreciated if someone could help me out with this ASAP. , Nick. you missing some inputs there ?
sparky3366 Posted August 22, 2007 Posted August 22, 2007 fire?tamper?fault? If at first you don't succeed...don't try skydiving!
Guest anguscanplay Posted August 22, 2007 Posted August 22, 2007 fire?tamper?fault? mains fail , zone exclude ?
