cjay Posted August 22, 2007 Posted August 22, 2007 Hello! Is it O.K. to install standard PIR detectors in a property having an 'open plan' design? I'm concerned about 'draught' causing an alarm. Any advice would be much appreciated.
arfur mo Posted August 22, 2007 Posted August 22, 2007 Hello!Is it O.K. to install standard PIR detectors in a property having an 'open plan' design? I'm concerned about 'draught' causing an alarm. Any advice would be much appreciated. most decent moderm pir's will work fine, but if you have severe enough air turbulance issue's to concern you, then fit either quad detectors or a bit more expensive but better, fit dual technology detectors regs alan If you think education is difficult, try being stupid!!!!
