Guest anguscanplay Posted August 23, 2007 Posted August 23, 2007 nope brain not working tonight - I tell you what I`ll ring em direct tommorrow and ask for you - check back then
Guest anguscanplay Posted August 24, 2007 Posted August 24, 2007 nope brain not working tonight - I tell you what I`ll ring em direct tommorrow and ask for you - check back then sorry Andy but man from Risco says " ha ha ha ha call yourself an engineer , of course it blody doesn`t " or something like that - it was hard to tell through his tears lol the new, new stuff will but what youve got
arfur mo Posted August 24, 2007 Posted August 24, 2007 just an idea, if you program the pro digi to phone your mobile then you will know the alarm has gone off at home due to the CLI feature and 'fax' beep but no voice message real basic maybe, but it will still work for your needs. regs alan If you think education is difficult, try being stupid!!!!
andymac Posted August 24, 2007 Author Posted August 24, 2007 just an idea, if you program the pro digi to phone your mobile then you will know the alarm has gone off at home due to the CLI feature and 'fax' beep but no voice message real basic maybe, but it will still work for your needs. regs alan Angus, Arfur mo, thanks both for your time, will let you know how i get on over the weekend, will try the pro digi and see if it works, if it does not will a speech dialler be able to tell me which zone has been triggered (like on my mums eurosec)? Thanks, Andy
alterEGO Posted August 24, 2007 Posted August 24, 2007 Angus, Arfur mo,thanks both for your time, will let you know how i get on over the weekend, will try the pro digi and see if it works, if it does not will a speech dialler be able to tell me which zone has been triggered (like on my mums eurosec)? Thanks, Andy no, hers is built in to the panel. for that you will need a different panel, either a eurosec CPX, GT 490X OR GT 595.
arfur mo Posted August 24, 2007 Posted August 24, 2007 Angus, Arfur mo,thanks both for your time, will let you know how i get on over the weekend, will try the pro digi and see if it works, if it does not will a speech dialler be able to tell me which zone has been triggered (like on my mums eurosec)? Thanks, Andy your welcome, but to be honest the short answer is no! the Vo Com being integral will do this as you know, but the digi can not transmit a code as it's designed for ARC receiver use. the Vo Com is not available as a standalone unit from Gardtec (more's the pitty) and no others interface to that degree level. regs alan If you think education is difficult, try being stupid!!!!
andymac Posted August 24, 2007 Author Posted August 24, 2007 Thanks alter ego, forgot you before. Will give you an update as and when. Andy
