Aritech Alarm Changing The Number To Dial
johndeff
If the dialler in the panel is an Aritech dialler, calls can only be received by a receiving station that has the equipment to recognise the call. If you want the panel to dial a number such as a mobile then you will need to install a speech dialler to the system.
I believe this is correct. If anyone knows different I stand corrected.
Simon
Simon
You are right about this Simon and if it is an Aritech dialler this will be locked with an engineer code as well as the control panel
Simon
It all depends which Aritech dialler you have and if it has the voice module installed. That said you will still need the engineer code to program it.
Your best bet is to call out your local PSA registered installer as it may need resetting
