pauls Posted August 23, 2007 Posted August 23, 2007 hi all, does anyone know where i can get the pinout data from the sensormatic touch tracker,american dynamics give you all the manuals on everything apart from the pin data on the back of the unit ,regards paul
PAULTHEFISH Posted August 24, 2007 Posted August 24, 2007 Hi pauls Do you mean the connections on the RJ45 lead or the green block connections on the EIM box
pauls Posted August 24, 2007 Author Posted August 24, 2007 Hi pauls Do you mean the connections on the RJ45 lead or the green block connections on the EIM box hi paul, yer the connections on the rj45,which plugs into the back of the tracker controller,i dont have the lead so i going to make one up, regards paul
PAULTHEFISH Posted August 24, 2007 Posted August 24, 2007 hi paul, yer the connections on the rj45,which plugs into the back of the tracker controller,i dont have the lead so i going to make one up, regards paul Looking at the plug with the clip facing down 1.red 2.blue 3.pink 4.grey 5.yellow 6.green 7.brown 8.white And then the opposite end of the cable wants to be in reverse 1.white 2.brown 3.green 4.yellow 5.grey 6.blue 8.red
pauls Posted August 25, 2007 Author Posted August 25, 2007 Looking at the plug with the clip facing down 1.red 2.blue 3.pink 4.grey 5.yellow 6.green 7.brown 8.white And then the opposite end of the cable wants to be in reverse 1.white 2.brown 3.green 4.yellow 5.grey 6.blue 8.red hi paul. thats great mate just wasnt sure about what went where and didnt want to blow the thing up,, mate regards paul
