Guest den123 Posted April 22, 2004 Posted April 22, 2004 hi guys tryed for 2days to try to work out how to program it still cant get it to do what i want i wont to set all pirs in the day then at night omit the bedroom when the system is off i walk in one room the alarm gose off can anyone help me please to program it thanks dennis
morph Posted April 23, 2004 Posted April 23, 2004 did the engineer set this facillity up for you when the system was installed, this is known as a part set. Colin.
Guest slim Posted April 24, 2004 Posted April 24, 2004 Assuming the bedroom pir is prog'd for part set, then set the system in the normal way - when you get an exit tone press yes again, it will display p/setting and a pulsed sounder - press yes a second time to silent part set. To prog a zone for part set - enter eng mode - zones, types then enable part in the zone for bedroom pir Regards
Guest den123 Posted April 25, 2004 Posted April 25, 2004 can i say a very big thanks for all the help you have give me
morph Posted April 26, 2004 Posted April 26, 2004 CHANGE THE PANEL OR OMIT THE ZONE Oakpark1 Rubbish, as Den123 has already found out there is absolutely no need to change the panel, when programming the panel correctly is all that is required. Simply ommiting the zone does not work as he would have had to omit two zones and this would leave a large part of the downstairs unprotected. Colin.
