Accenta G3 Door And Button Panel Chime Gone, Pls Help
delnoch13
Hi,
I have an Accenta G3 alarm and recently the beep I usually hear from the front door being opened and the beeps from entering the alarm code have gone, although when I'm inputting my
code I can hear it faintly from upstairs where the main accenta g3 box is.
Is this something that I'll need an engineer to fix as the alarm itself works fine?
Guest anguscanplay
Hi,
Hello there , sounds like your describing the loudspeaker has stopped working , maybe a damaged cable or a faulty unit its probably best to get a local firm round to check it and the control unit too
Ok, I don't know much about this kind of stuff so engineer it is.
Many thanks.
