andymac Posted September 7, 2007 Author Posted September 7, 2007 Hi all, I got a timer board from cpc which works a treat. Thanks for your help. For the record im nothing to do with "crapday", he's got me confused with someone else, he pm'd me asking if i was in scotland! when clearly im in manchester! Ta Andy
barooga Posted September 7, 2007 Posted September 7, 2007 Hi all,I got a timer board from cpc which works a treat. Thanks for your help. For the record im nothing to do with "crapday", he's got me confused with someone else, he pm'd me asking if i was in scotland! when clearly im in manchester! Ta Andy Don't worry Andy, confused is something he specialises in Growing old is mandatory, growing up is optional
mjw Posted September 8, 2007 Posted September 8, 2007 lol - you didnt see it before i HAD to edit it lol sometimes the advice ( and he got the same on his fabled " other forums " ) is just that - its beyond your ability as a DIY`ER well as i haver said before any idiot can start a fire
nikko Posted September 8, 2007 Posted September 8, 2007 he didnt mean switch the mains through the panel - did he ? Yes I understand the need to clarify this point to members of the public, but his mains siren should come with instructions as to what is to be used as a trigger. I went up into the attic...I found a Stradavarius & a Picasso. Unfortunately..... Stradavarius couldn't paint, and Picasso made a shocking fiddle. My Facebook page...http://www.facebook.com/home.php#/profile.php?id=1279556853&ref=name
mjw Posted September 8, 2007 Posted September 8, 2007 Yes I understand the need to clarify this point to members of the public, but his mains siren should come with instructions as to what is to be used as a trigger. should it though??...this is a bit of kit which is aimed at the professional market,and therfore as a professional you should'nt need to be told
buddyboy Posted September 8, 2007 Posted September 8, 2007 i havnt read half of the replies so if someone has said this then ignore it. if its a new sab you have got it should have its own cut off timer in it, so you can wire the bell trigger into the strobe and then wire the master blaster into the bell trig and programme the time as whatever you want. this should work, the timer in the sab will stop the bell ringing, the strobe will still flash and the blaster will be programmed to whatever time you want. im sure someone will say im wrong and it wont work but it was just an idea. Trade Intruder
arfur mo Posted September 8, 2007 Posted September 8, 2007 i havnt read half of the replies so if someone has said this then ignore it.if its a new sab you have got it should have its own cut off timer in it, so you can wire the bell trigger into the strobe and then wire the master blaster into the bell trig and programme the time as whatever you want. this should work, the timer in the sab will stop the bell ringing, the strobe will still flash and the blaster will be programmed to whatever time you want. im sure someone will say im wrong and it wont work but it was just an idea. hi buddyboy, that wiring config would have a albeit minor 'flaw' as the panel may be set to auto re-arm, with the strobe continuing for a period longer than the siren setting. so the panel auto resets with the strobe still active, o on the next activation only the internal siren would action if a further alarm occurred within the strobe on time. regs alan If you think education is difficult, try being stupid!!!!
arfur mo Posted September 8, 2007 Posted September 8, 2007 should it though??...this is a bit of kit which is aimed at the professional market,and therfore as a professional you should'nt need to be told but the advice is in the public sector so we have a 'duty of care' as professionals to be very clear where severe hazards exist to the non aware or amateur. either way no harm in stressing caution, an offended professional is better than a dead diyer and his family imo - yes? regs alan If you think education is difficult, try being stupid!!!!
mjw Posted September 8, 2007 Posted September 8, 2007 but the advice is in the public sector so we have a 'duty of care' as professionals to be very clear where severe hazards exist to the non aware or amateur.either way no harm in stressing caution, an offended professional is better than a dead diyer and his family imo - yes? regs alan i am with you all the way,the point i was trying(and sadly failing) to make was that a bit of kit aimed at the pro market shouldn't be made available to any body i can see it now a very nice master blaster situated in the loft space of a new build terrace house(fitted by a diyer) with endless bell time and the resident away on 2 weeks hols think the neighbours may well start a lynch mob
Guest anguscanplay Posted September 8, 2007 Posted September 8, 2007 i am with you all the way,the point i was trying(and sadly failing) to make was that a bit of kit aimed at the pro market shouldn't be made available to any body i can see it now a very nice master blaster situated in the loft space of a new build terrace house(fitted by a diyer) with endless bell time and the resident away on 2 weeks hols think the neighbours may well start a lynch mob the fire brigade ( there to deal with the roof catching fire from the motor over running ) could use their hoses as crowd control - lol
