Connecting Alarm To Door Lock
Iain
I'm about to replace a system at a premises set up so turning the key in the exit door deadlock also terminates the exit set
Can anyone tell me what kit I would need to replace this? Is it a special lock, or is it a contact that can be put into an existing deadlock.
I've tried researching it, but have come up with nothing, and don't want to get to site wihtout the correct kit
I'm hoping soeone can at least point me in the right direction to look
cheers
cheers
We used to make them manually with a tiny micro switch inside the lock,but as far as im aware you can buy one complete
Guest Dave the alarm man
wooden door? 99.9% sure it will be Chubb 3G114 with you not knowing that I assume you do not wort inthe trade?
replace? why either lever kit or mircoswitch should repair it no probs.... (asuming your talking the lock?)
renewing controls? proper 100 quid for the metal endstation type rather than the plastic stick in your house type
I'm replacing the panel (it's an ADE Ultimate that's packed up), and as the old system used ID biscuits, whilst new system will be using EOL, it's gonna be easier replacing everything
I'll check the lock out, and as long as it's working ok, I'll leave it be.
cheers for that,
And no, I don;t work in the trade, but have been installing privately as a sideline for a number of years (mainly domestic, and either texecom R8+ or Gardtec panels)
Shame that doesn't qualify me for trade access on here LOL
Thanks for the help
Iain
I assume rewiring?
  Iain said:
Yes, I'll be rewiring everything. It's the only ways forward
thats okay, as lock setting & 60 zone (point) ade ultimate, sounds (maybe) like a large commercial sytem that is (was) on signalling
why say that nless condition is an issue?
several panels out there from different makers can us iD and replace an ultimate/karizma, if your under 30 zones it's a breeze but you might have to run extra wires for the keypad.
regs
alan
Guest anguscanplay
Thanks for the help
Iain
sorry but some of us dont see the need for the " LOL " at the end of that statement , but surely " as a sideline for a number of years ....." means you are a legitimat business ( insurance etc ) ?
no it's a Personal Jeoperdy' set up (aka PJ).
regs
alan
