tinnitus Posted September 10, 2007 Posted September 10, 2007 chaps, nice easy job today. swap old ensign panel for a new meridian. replace 6 pir's for iWise quad's and fit resistors in pa's. nice enough panel, easy to program. well it is if the RKP is in the box. So, travel back to the store and pick one up, get back, fit it, its FKD. Chief engineer drives over with another, this sorts the problem and highlight one of the quads as faulty, typical day I'm sure you will agree. anyway, after the initial addressing of the rkp it went blank, like it does then a little timer appeared, anyone else had this? castle tech line told me the nvm was not programed, i tried swapping them, it didn't fix it.
Guest Dave the alarm man Posted September 10, 2007 Posted September 10, 2007 cotemporary or brick wolfie?
mjw Posted September 10, 2007 Posted September 10, 2007 chaps,nice easy job today. swap old ensign panel for a new meridian. replace 6 pir's for iWise quad's and fit resistors in pa's. nice enough panel, easy to program. well it is if the RKP is in the box. So, travel back to the store and pick one up, get back, fit it, its FKD. Chief engineer drives over with another, this sorts the problem and highlight one of the quads as faulty, typical day I'm sure you will agree. anyway, after the initial addressing of the rkp it went blank, like it does then a little timer appeared, anyone else had this? castle tech line told me the nvm was not programed, i tried swapping them, it didn't fix it. if i remeber i think you hold 'd' down on the rkp for a little while,although its been a while though since using my last one,also castle care tech you do know they are pyronix??
Guest Dave the alarm man Posted September 10, 2007 Posted September 10, 2007 if i remeber i think you hold 'd' down on the rkp for a little while,although its been a while though you thinking he's got it programmed to an address not used on the panel?
tinnitus Posted September 10, 2007 Author Posted September 10, 2007 if i remeber i think you hold 'd' down on the rkp for a little while,although its been a while though since using my last one,also castle care tech you do know they are pyronix??nah, that just allows you to reprogram the rkp. Information removed following complaints tried all the usual stuff. i think the rkp has some kind of nvm soldered on and it was not programed.cotemporary or brick wolfie?lol, new type mr cant be ar s ed but i will anywayyou thinking he's got it programmed to an address not used on the panel? you adress it from the rkp, it cant be changed by moving switches or turning pots.
Guest Dave the alarm man Posted September 10, 2007 Posted September 10, 2007 as 00? or 01? it replace the brick type? your euro 12 20/28 or 44+?
tinnitus Posted September 10, 2007 Author Posted September 10, 2007 as 00? or 01?it replace the brick type? your euro 12 20/28 or 44+? 00 new type with blue l.e.d's euro one to be exact. should have said but it wont make a differance. anyway, as i said the rkp was fkd, nothing else, but have you had the problem where a little timer appears? i imagine its like a burn in timer for a factory PIA test.
mjw Posted September 10, 2007 Posted September 10, 2007 you thinking he's got it programmed to an address not used on the panel? yep and it sounded like it but obviously not?????
Guest anguscanplay Posted September 10, 2007 Posted September 10, 2007 anyway, as i said the rkp was fkd, nothing else, but have you had the problem where a little timer appears? i imagine its like a burn in timer for a factory PIA test. home automation module - telling you the eggs are ready ?
tinnitus Posted September 10, 2007 Author Posted September 10, 2007 home automation module - telling you the eggs are ready ? are you mocking me?
