Part Arm Query - Texecom 24
sennajc
Hi there,
I have set my front door to entry/exit 1 (zone 1)and hall PIR(zone 2) to guard access. I have programmed landing as Omit 1. When I part-arm 1, I get a return saying Zone 2, Hall Pir not secure.
In other words, when I part arm the hall pir is picking my movement up and preventing the setting - even though it is programmed as guard access.
Can anyone help me here - as usual I reckon I'm missing something obvious!
Hi there,
I have set my front door to entry/exit 1 (zone 1)and hall PIR(zone 2) to gueard access. I have programmed landing as Omit 1. When I part-arm 1, I get a return saying Zone 2, Hall Pir not secure.
In other words, when I part arm the hall pir is picking my movement up and preventing the setting - even though it is programmed as gueard access.
Can anyone hel me here - as usual I reckon I'm missing something obvious!
don't use that panel but with others it should be proged as part e/e not access, it should then also act as an access zone when in full set.
Hi there,
The default for Part Arm 1 is instant, try changing it to "Timed" under Options (manual page 36) :hmm:
