Pro Digi
andymac
Hi all,
I have just intalled my pro digi to my gardtec 816 panel. All is sort of well except that every time i set/unset the system it calls me!
I have followed instructions in the installation manual, but when i plugged the pro digi onto the board i got some extra menu options which i dont know what do, they are channel r/rep
program digi test etc.
there is no reference to these in the panel installation manual, is there a seperate manual for the pro digi?
Any help would be appreciated.
Thanks,
Andy
Hi all,
there is no reference to these in the panel installation manual, is there a separate manual for the pro digi?
Thanks,
Andy
Sounds like in the menu you have set the reports for set and unset procedures.
Without looking at the manual i cant really tell you..There should be a technical helpline with your manual ,they will know straight away what your doing wrong.
hi Andy
i'm assuming you know the 'pro digi' is not a voice dialer but a digital communicator as such should go via an alarm receiving center who then call you in turn? if your sending it to your phone and rely on the number displayed via CLI on your mobil.
you will get several calls on an activation and an FTC (fail to communicate) message on the panels log and display, so best to program for abort, also for no comms in part set and turn off 'restore', or going to the toilet and accidentally setting off the alarm will mean your phone ringing several times.
if you have used the fly lead with blue plugs on, then the digi type needs to be set to 'Gardtec' and the set/unset reporting option needs to be switched off on channel 4 in the same menu under 'reporting'.
you also need to remove the resistor bottom left of the main pcb connected to line fault terminal, older panels had a hard wire link and if left connected it can seriously damage the panel, the later resistor can affect proper programming of the pro digi.
regs
alan
Hi all,
Thanks,
Andy
hi Andy
regs
alan
If that doesnt answer your question nothing will.Good answer ..........
thars very kind an observation markovitch
i have never felt so loved and humble in my entire tenure of this forum :signthankspin:
:wub:
regs
alan
Guest anguscanplay
hi Andy
regs
alan
It was you you wally who told him to do it this way whilst ai was ringing tech support
It does ( bar the obvious mistake ) but theres also far too much information given to a member of the public ( might have to go replace all my old prodigi`s now ) actually its a good example of how risco took their eye of the ball and allowed untrained , unskilled purchasers access to engineer support.
:hmm: what on earth are you on about Angus where did i tell him to do anything prior to that post?
sussed - have you been at my rusty tin of Ovaltine behind my back again you rouge? :bruce_h4h:
he has got a pro digi off ebay i'd expect has no instructions with it, he has plugged it in (not the hardest job in the world) and getting set/unsets (wonder who still uses that feature on a digi these days?), no engineer codes or default advice given, so tell me where is my advice askew? :wacko:
regs
Alan (aka i'm always totally wrong even when totally right according to Angus and the "ruling 'alf" that is :yes: )
Guest anguscanplay
just an idea,
if you program the pro digi to phone your mobile then you will know the alarm has gone off at home due to the CLI feature and 'fax' beep but no voice message ;)
real basic maybe, but it will still work for your needs.
regs
alan
ring any bells Arfur - a simple apology will surfice
Angus
