Pro Digi
andymac
:owned::roflmao:
Eagerly waiting for a response from Arthur.
Angus i think you over reacted to Authurs info what he gave out,i dont think a potential intruder could gain any useful info on how to comprimise the installation.
Guest anguscanplay
I`ll message you - take me of block - lol
:withstupid:
All comments in this post are my own views and do not necessarily reflect the views of my employer
ring any bells Arfur - a simple apology will surfice
Angus
no apology required from me,
the clue in that initial response is the term "it will be real basic". heard no more so assume he accepted the limitations or had given up on the idea. based on the limited information i am justified to think he would hard wire rather than use a serial link, and doing would not produce the set/unset signals he has suffered by actually using the factory serial cable.
now i could have covered all this but i get noaned at for my long posts, ao it seems the general public don't need such in depth advice but my so called peers do :rolleyes:
then it was muted in a new thread so more advice was deemed required and was given -and very accurately.
so what was the 'obvious mistake" you referred to then Angus?
(oih! give me back my rusty tin you varmint)
regs
alan
LOL, busted
as ifhere is some very sound advice especially relating to me, make very sure of your ground before you go into battle with mesee reply aboveregsalan
:owned::roflmao:
i'll just ditto my last postregsalan
Guest anguscanplay
regs
alan
you were busted good and proper just accept it gracefully you old goat - as for the mistake :no: I aint going to tell you in the public forum - its in the headers ( but really , telling JP what to proggrame on a digi was a bigger enough one anyway )
Angus
Angus
nope! (and i'm still waiting for you to come good on your !/2 hour boast which was into about 1 1/2 hours when that post was closed by you favourite mod saving your beacon)
your not on my ignore list - so a pm will do
are you seriously saying a x490 would ever be used for an arc system requiring open/closed signals via a digi by any decent registered alarm company Angus? words would fail me if that were true
the j/p will need the engineer code as the setting is in the engineering section, all i have given him is the relevant area he needs to look at for open and closed signals. without a valid engineers code he and anyone else (not being a Gardtec aware engineer) is totally and utterly stuffed like you were on the fobs ;) .
you really will have to try harder old fruit
regs
alan
Guest anguscanplay
to be fair it was one of your busiest weeks - I was spoiled for choice , then they closed it
whats a 490x got to do with owt - this guy " nicked " the old 816 from his Dr Dads surgery
the j/p will need the engineer code as the setting is in the engineering section, all i have given him is the relevant area he needs to look at for open and closed signals. without a valid engineers code he and anyone else (not being a Gartec aware engineer) is totally and utterly stuffed.
go read what you said again - how can I put this - PLUGS IN
regs
alan
when your loosing the plot this often it`s hardly any effort at all - cheers ( sweets and babies springs to mind )
Regards - listen I admitted been wrong ( and still owe you a breakfast )
Angus
