Guest anguscanplay Posted September 20, 2007 Posted September 20, 2007 Letting it fully set then activating an alarm condition by walk past pir is it sounding the internal speaker , siren or keypad ? I know it sounds patronizing but set the system , leave the premises count to a couple of thousand then re-enter and let the timers lapse ( I had a pir this week took me three or four attempts waiting for it to re awake ) Angus
Neutech Posted September 29, 2007 Posted September 29, 2007 Have you let the battery charge the full 24hours on the siren? Have you connected the 240v -12v transformer? If you have done the above then the siren unit faulty Fitted a few ESP but never had problems Hope you get sorted
parrot Posted October 30, 2007 Posted October 30, 2007 Have you let the battery charge the full 24hours on the siren?Have you connected the 240v -12v transformer? If you have done the above then the siren unit faulty Fitted a few ESP but never had problems Hope you get sorted Got same problem. going to check if i've left jumper on transmit or register in sounder box. Tried external siten test and that is ok. If you find a solution please let me know.
