Paragon Plus
ScaryCactus
Guest anguscanplay
like I said at the top
" how did you test............." or rephrased " what fault is it showing ?"
Angus
Sorry Angus, I thought you were asking how I tested the strobe. The control box isn't specific as to what the fault is, it just has an orange light illuminated with fault printed on the lid next to it. There is no explanation of what type of fault could occur, this single led is either on or off. Unfortunatly for me its on at the moment. I'm going to try the sequence that arfur mo explained in his last post.
According to the manual, the fault light will illuminate due to one or more of the following conditions:
Blown bell fuse
Blown Auxiliary fuse
No mains supply
Are all of your detectors lighting up OK? Does your bell box work other than the strobe light? (ie sounds when you test it, warning LEDs still flashing)?
Trade Member
Guest anguscanplay
be the battery ( the ends of the strobe are black anyway )
POWER IT DOWN TOTALLY
CONNECT MAINS
CONNECT NEW BATTERY
CLOSE ALL OPEN LIDS ETC
PRESS RESET ( CHECK LIDS IF IT DOESNT RESET FIRST TIME )
REGARDS
Angus
Blown bell fuse
No mains supply
All detectors light up and the bell box works. I found 3 fuses in the control box which were all ok. I couldnt find a fuse in the bell box but it went off as soon as I removed the cover, glad I remembered to put my ear defenders on. The leds are still flashing. The mains light on the control box is illuminated when power is going to the unit.
Guest anguscanplay
bet its starting to feel hot ( top left hand side ) - battery
