Fermax Door Entry
Alarm Co
hi guys
was on site for phew hours today trying to find fault with fermax city light dooor entry system, audio and video,,
problem is ,, if anyones familier with it ,
when some one buzzez a phone you get the pic come on the monitor on the hand set but no, wasnt happening,, but if you press the monitor button on the handset you get picture
so spoke to technical to no avail, tryed all the usual flying leed from ct(camera triger)
on rear of out side camera to the video distributor ????
nothin, tryed diffrent camera module,, checked voltage at ct and poss when cam on had 8 volt,, belled out ct cable going back to video monitor ???????
has any one got any ideas
cheers guys
chris
hi guys
cheers guys
chris
Dosen't it sound like a fault with the handset-display unit not auto switching?
My Amateur Radio Forum
Guest anguscanplay
you meter out the switch they press ( once had an earwig behind one ) ?
got a block of six appartments and got a fault on all so it a problem with eather outside cam or controll junction box ?
Guest anguscanplay
if your getting a picture when you press the monitor button it wont be the camera
fault on cable from station ? does it buzz when they press the button ? sounds like the handset isnt getting its switch input
yerr got that prob on all six phones but why aint it sendin signal to phone ??
Guest anguscanplay
water int the callstation ? or cable fault somewhere between the station and the control
good old fashioned cable tracing required lol
He says he's done that mucker, if he "has" and there is voltage on his control cable then it must be a fault in the monitor switching..... :rolleyes:
yerr ran flying leed from camera ct straight to 3 on the video ditributor? no good the only thing i havnt done is wired camera mod direct on to video spliter ? this is a good one aint it?
